Found it.......(Terrigal Run Problems...) https://www.ausmini.com/forums/viewtopic.php?f=2&t=7809 |
Author: | kazjim [ Sat Jun 04, 2005 4:04 pm ] |
Post subject: | Found it.......(Terrigal Run Problems...) |
Hey all, finally got around to diagnosing the Brick... Guess what? ANOTHER FREAKING HEAD GASKET !! I was pretty sure that the head is a little warped, now I'm sure.... Less than 150Km on this one (Pair, actually) Clean Burn, right between 2 and 3.. same place it went the last two times... I would expect that if it was purely detonation causing it, it would be more "Random" on the cylinder that it targets... but its always between 2 and 3 ... Heads off to the machine shop on Monday..... Kev, maybe time to talk about one of your "DRMini Specials" .......... J |
Author: | 13secmini [ Sat Jun 04, 2005 4:31 pm ] |
james,, wouldnt have anything to do with them two leads being in the wrong spot maybe?? have you tried the acl gasket? Did u re torque the head? spose there are a few reasons why they keep blowing,, nothing to do with running 30psi of boost ![]() |
Author: | kazjim [ Sat Jun 04, 2005 4:39 pm ] |
Shhhh, it was only 16Psi on saturday.... Nahh, the leads were right to start with and they were only wrong for about 30 seconds..... Just a nice warped head..... (sounds like something Mrs KazJim says about me..... hhhmmmmm) J |
Author: | MiniK [ Sat Jun 04, 2005 4:56 pm ] |
Jim.... If you want to try the ACL gaskets let me know... Ive been a lazy git and still not gotten you a price. ![]() |
Author: | kazjim [ Sat Jun 04, 2005 5:01 pm ] |
Yes, Yes Yes !! I'll grab a few and make it worth your time.... Make it 3 ? Also, can you get the steel-backed Inlet / exhaust gaskets ? (Rover ones... EXCELLENT!!) Thanks... J |
Author: | MiniK [ Sat Jun 04, 2005 5:10 pm ] |
kazjim wrote: Yes, Yes Yes !!
I'll grab a few and make it worth your time.... Make it 3 ? Also, can you get the steel-backed Inlet / exhaust gaskets ? (Rover ones... EXCELLENT!!) Thanks... J I'll have to check the inlet/exhaust gaskets....I'll pay them a vist on monday and order some in if the price isnt too rough..It shouldn't be really. And then Ill post you a PM..sound good? |
Author: | drmini in aust [ Sat Jun 04, 2005 5:24 pm ] |
James, just fit a 940 or 1316 head, and BK450 turbo gasket = no more problems! Chamber size = whatever you want up to 30cc or so. ALL the smallbore heads flex more than the bigass 1275 ones do. ![]() |
Author: | kazjim [ Sat Jun 04, 2005 5:34 pm ] |
Only problem kev... you cleaned me out ! I'll have to chat with you by email..... Got a 1316 almost ready to go ? we'll work out a $$$ ... k ? MiniK... maybe hold off... i might need to order a different head gasket yet..... Cheers J |
Author: | drmini in aust [ Sat Jun 04, 2005 6:51 pm ] |
Take your pick James-- #1, 12G1316- needs exhaust seats but that's no problem to get done. I have some Rover unleaded inserts. #2, 12G1316- G.R. & I fixed the rusted inlet seat with a 4140 insert, it just needs all seats recut now and it's a goer. Both heads are bare now but I have 1 set of valves- If I were you I'd buy new ones. They are pretty cheap now. 1100S inlets 12G941 $14.12 each 1275 exhausts 12G1322 $20.32 each. Karcraft's prices- not worth mucking about with S/H is it. ![]() |
