Mini won't start. Help? See bottom post https://www.ausmini.com/forums/viewtopic.php?f=2&t=78101 |
Author: | Konzo [ Sun Aug 19, 2012 2:46 pm ] |
Post subject: | Mini won't start. Help? See bottom post |
I took off distributor and stupidly disconnected the leads from it. Can someone confirm which is the number one spark plug? Also look at picture and tell me if I have them in correct order? Distributor cap positioned how it is in the engine bay. Also, there is a 4 on the inside of the cap, it is positioned between the 1 & 3 in that picture. Confirm which is the 1 piston? Radiator side (right side of picture) or other side? ![]() Uploaded with ImageShack.us |
Author: | drmini in aust [ Sun Aug 19, 2012 2:54 pm ] |
No pic shows. Convention is #1 is at about 1 o'clock, then number 3,4,2 anti-clockwise. |
Author: | Konzo [ Sun Aug 19, 2012 2:56 pm ] |
Pic now. Post updated. |
Author: | drmini in aust [ Sun Aug 19, 2012 3:00 pm ] |
#1 is rad end. Unless your dizzy shaft is out of position, #1 lead is wrong. Also you have the leads mixed up, see my post above. |
Author: | Konzo [ Sun Aug 19, 2012 3:15 pm ] |
Is the 4 the zero point (on the inside of the cap)? So would be 1-3-4-2 from the zero point anti-clockwise? |
Author: | drmini in aust [ Sun Aug 19, 2012 3:23 pm ] |
Konzo wrote: Is the 4 the zero point (on the inside of the cap)?
So would be 1-3-4-2 from the zero point anti-clockwise? Ignore the zero point. Put the leads in as I suggested in my post above, it should work- if it doesn't fire and run, move all 4 leads 1 place anti-clockwise. |
Author: | Konzo [ Sun Aug 19, 2012 3:31 pm ] |
Excellent Thankyou that fixed the back fire problem ![]() |
Author: | Konzo [ Sun Aug 19, 2012 4:35 pm ] |
Now just cranks over won't start. Any tips? See video http://www.youtube.com/watch?v=HxXCVgTn ... ata_player It's been sitting for a while. Managed to get it started last weekend and drive for about an hour no dramas. Now just won't kick over ![]() |
Author: | adamstuart [ Sun Aug 19, 2012 4:48 pm ] |
Check the plugs. If they're black as soot, it won't start. Since the plugs are in the correct order, assuming you have fuel, make sure you're getting spark into the cylinder. |
Author: | mattsmadmini [ Sun Aug 19, 2012 4:57 pm ] |
as above, and a touch of start ya bastard never hurts ![]() |
Author: | Konzo [ Sun Aug 19, 2012 4:58 pm ] |
mattsmadmini wrote: as above, and a touch of start ya bastard never hurts
![]() tried start ya didn't help. I'll pull plugs out and clean them again but they are fairly new. |
Author: | d1ck0 [ Sun Aug 19, 2012 5:03 pm ] |
Have you wound it by hand so No1 is on TDC and checked where your Rotor is pointing? Just to make sure your Dizzy is correct as a starting point. Cheers Dicko. |
Author: | Konzo [ Sun Aug 19, 2012 5:16 pm ] |
Clean the plugs again and with some persistence the little beauty started ![]() |
Author: | Konzo [ Sun Aug 19, 2012 5:25 pm ] |
Coughing n splattering but drove ok. After a few laps of the block it seemed better. Now time to take the twin su's to get tuned properly??? Would that be causing the splatter etc or would that be a fuel issue? |
Author: | Konzo [ Sun Aug 19, 2012 5:31 pm ] |
http://www.youtube.com/watch?v=duGdKxSY ... ata_player |
