Key/Locksmith question. (Sydney)
https://www.ausmini.com/forums/viewtopic.php?f=2&t=78108
Author:  Morris 1100 [ Sun Aug 19, 2012 8:38 pm ]
Post subject:  Key/Locksmith question. (Sydney)
Does anyone know a locksmith in Sydney that will cut a key from the original key code number?
Author:  d1ck0 [ Sun Aug 19, 2012 8:43 pm ]
I know one in Nelson Bay.....
Most good locksmiths should be able to do that. If you get stuck let me know
Dicko.
Author:  Morris 1100 [ Sun Aug 19, 2012 8:45 pm ]
Thanks Dicko, it is for a friend in Sydney. If she can't find someone locally I will shop around!
Author:  mini1990 [ Sun Aug 19, 2012 8:51 pm ]
There is a locksmith who did this for me up in Mona Vale (Northern Beaches) about 3 weeks ago. 20 Bucks for 3 keys made from the code on the boot lock.
Author:  John Smidt [ Sun Aug 19, 2012 9:00 pm ]
Post subject:  Re: Key/Locksmith question. (Sydney)
If It is a FS Key I can cut them for You from The number I have a sample of every Mini Key in The FS Range
Author:  Morris 1100 [ Sun Aug 19, 2012 9:08 pm ]
Great info everyone! I will pass it along.
Author:  ryan [ Sun Aug 19, 2012 9:27 pm ]
Sorry to hi jack.
How hard it it to have locks re keyed?
I have three different keys. Boot, door, ignition.
Ryan
Author:  guna mk1 [ Sun Aug 19, 2012 9:41 pm ]
Not that hard for a locksmith to do
Author:  Morris 1100 [ Sun Aug 19, 2012 9:46 pm ]
I've done it a few times myself. On a roundy I would probably match the ignition and boot to the existing door lock to save pulling the door lock out.
Author:  Bubbacluby [ Mon Aug 20, 2012 10:23 am ]
I have asked a similar question here at the local locksmiths.
I had a key and wanted some locks changed to match the key. They said they couldnt do it because the wafers inside are too old and they cant get them.
I thought they were a pretty useless locksmith when he told me that.
So if i want a boot lock keyed the same as my ignition and door locks, is the only way to get half a dozen bootlocks for them to pull apart and hopefuly make a correct one?
Or can a "good" locksmith do this without any trouble?
Author:  John Smidt [ Mon Aug 20, 2012 11:59 am ]
A good lock smith should be able to do it for You, Some simplly put the key number you want in the barrell then file down the wafers that are sitting up,
For the most part this is not a great way to do it,
If You have a selection of locks then take the barrels out and read the key number
stamped on the barrell you may match a full set up with what You have
if not see if You can buy the missing locks keyed the way you want
That is if You cannot find a locksmith to do the job You want
Author:  phillb [ Mon Aug 20, 2012 1:25 pm ]
I've done a few by using the method where you insert the key you want to work and filing down the wafers. It's easy to do yourself.
John, interested to know why you say this is not a good idea. Is it because it makes the lock less secure?? (the old key would still work)
Author:  John Smidt [ Mon Aug 20, 2012 2:55 pm ]
If You only have to file down one wafer or maybe 2 it may be ok
this will mean the original key and the new key will do the job,
However sometimes more than two keys will operate the lock
I have seen it when this method is used that a lot of keys will operate
the lock
as You may have found, sometimes you may file alot of one waffer and a little of
possibly two more, This will then raise the chance of more keys fitting the same lock
Having said this My Dad who never locked a car Said that locks kept honest people
out and caused the crooks to damage You car to get in
