It is currently Sun Jul 20, 2025 8:34 am
 Post subject: 77' Moke Differences ?
PostPosted: Fri Aug 24, 2012 7:38 pm
Die Die Die!!
as im new to the moke scene could someone tell me what is different between a 77' moke and a mini
are there any subframe differences ?
i know the rear wheel cylinders are larger ? 11/16"
is there anything else ?
sorry for all the questions
PostPosted: Fri Aug 24, 2012 7:45 pm
Between a '77 and what?
PostPosted: Fri Aug 24, 2012 8:14 pm
Die Die Die!!
oops, between a 77'moke and a mini
PostPosted: Fri Aug 24, 2012 8:18 pm
Well its a moke, so everythings different.
PostPosted: Fri Aug 24, 2012 8:19 pm
If this relates to the Sirion project, there is no substantial difference between subframes. The differences which exist are limited to bumper bar mounting options. I think any old mini subframe will go straight in.
Trailing arms are different. Hrrrmmm, what else?
I can't remember. Perhaps wheel hubs too?
PostPosted: Fri Aug 24, 2012 8:20 pm
Eg: my Moke has a subframe from a Deluxe or a K or some other late roundy.
PostPosted: Fri Aug 24, 2012 8:21 pm
If you drop the front subframe complete with engine, brakes, etc,, that is all Mini. Rack is the same, Headlights, Master Cylinder.
If you drop the rear the rear arms are longer and not mini. Everything else if different, i.e. the body. :lol:
WD40'll fix it!
If it don't, use a big hammer!
Die Die Die!!
well if im going to pull the subframes appart and get them powder coated etc, i was going to buy kits for the trailing arms etc (if needed of course) and if i look for parts on minispares, they dont really stock "moke" parts but i was wondering if they are different to mini parts for this purpose
know what i mean ? :)
PostPosted: Fri Aug 24, 2012 8:22 pm
Yeah, I know what you mean.
I think from a subframe perspective you're fine.
PostPosted: Fri Aug 24, 2012 8:24 pm
Just get Mini stuff, you'll be right :wink:
WD40'll fix it!
The front frame is a Mini frame with a couple of add ons for bumper mounts and sump guard.
Die Die Die!!
how about brakes, and perhaps even steering racks ?
i intend to replace the front brakes with discs, and renew the rear..
PostPosted: Fri Aug 24, 2012 8:34 pm
Brakes are mini. Racks are posted to Dr Mini :lol:
WD40'll fix it!
PostPosted: Fri Aug 24, 2012 8:52 pm
Mini King has rebuilt Oz racks for later Mokes, with Morris 1100 tierods on em. This gives a bit more thread engagement in the tierod ends.
But really these are for the last of the Mokes which had funny steering arms; on a `77 either these or a std Mini rack should fit OK.
PostPosted: Fri Aug 24, 2012 9:46 pm
The Mini King
Also if you are fitting imported 8.4 disc brake assy S/H they often had steering arms
that did not give You enough thread on Your tie rods When fitting the Tie rod Ends
Front moke subframes As Morris 1100 Said
Rear subframes are standard dry frames with some extra sheet metal bits welded
on for extra strength
Users browsing this forum: No registered users and 67 guests
