Fuse Box
https://www.ausmini.com/forums/viewtopic.php?f=2&t=78144
Author:  tracytracey [ Wed Aug 22, 2012 5:22 pm ]
Post subject:  Fuse Box
Hi, my fuse box will no longer securely hold one of the fuses am I better to order a new 2 glass fuse one or pick up a new blade style one from a local auto shop? Cheers.
Author:  adamstuart [ Wed Aug 22, 2012 5:48 pm ]
I would be sticking with the old 2 fuse style.
It's not great, but it's worked fine all these years.
They're also cheap as chips and no fiddling around to get it to fit.
Author:  frednutz&co [ Wed Aug 22, 2012 5:49 pm ]
is it a display concourse car
go original
daily driver ==upgrade to blade :D :D
Author:  Nicho [ Wed Aug 22, 2012 7:55 pm ]
Keep it original
I got some Lucas fuses if someone wants the for a concourse car. They're in my 76 but it's not going to stay original
Author:  kiwiinwgtn [ Wed Aug 22, 2012 9:16 pm ]
Can you actually get a bladed fuse box that will fit straight in
The problem i have encountered is that you need a fuse box with a double row of connectors and most aftermarket one only have a single row
Author:  John Smidt [ Wed Aug 22, 2012 10:22 pm ]
Do The poor old spare parts salesman a favour, Use the original type,
so when someone wants a fuse box in future for this car and says to the spare parts Man I want a fuse box for a Aust Mini year model Whatever
The parts Man will supply the correct Part.
I say this in jest However It Is True :wink:
Author:  Convertible Mini [ Thu Aug 23, 2012 5:26 am ]
Post subject:  Lucas fuse box
There was never anything wrong with Lucas fuse boxes. As long as they are kept clean and with the cover on. They have been around long enough to prove themselves. Unless you are doing a custom wiring Job where you need more fused circuits stick to the original one there are plenty available like John MINI KING Said.
Author:  kiwiinwgtn [ Thu Aug 23, 2012 6:07 pm ]
Agree re the fuse box. Keep it original
I like the retro look but do have one car I have customized to my liking that could do with a better fuse box arrangement
The other cars can stay lucas..
Author:  bnicho [ Fri Aug 24, 2012 3:25 pm ]
A recent idea that was suggested to me was to use TWO standard fuse boxes. That way the fuse box is easy to replace and you don't have to cut/chop/change the loom at all.
Sounds like a smart solution to me. :)
Author:  woodwormm [ Fri Aug 24, 2012 5:17 pm ]
I like the idea of keeping the std box, but where does one procure the smoke from? I need to reinstall some into my lucas lectrics.. :P
Author:  thomas_hb [ Fri Aug 24, 2012 7:47 pm ]
What about just putting some pliers on the contacts and bending them back in a bit so they're tighter and the fuse doesn't fall out?
