It is currently Sat Jul 19, 2025 8:45 pm
PostPosted: Thu Aug 23, 2012 7:34 pm
Ahh searching searching I'm getting confused.
I have an S 1275 block that came with caps but no bolts.
Can I use bolts or a stud kit?
What size are the bolts?
I have read about the stud kit fouling on the gearbox.
PostPosted: Thu Aug 23, 2012 8:14 pm
All Cooper S engines had studs..
The 2 centre main studs are longer than the outers.
Engine numbers for S are 9FSAY and 9FXEY.
Both had open cam follower chests at back of block.
1100 S had bolts for main brg caps.
Cooper S block will fit all syncro boxes but if a 3 speed box you much check case number. :D
PostPosted: Thu Aug 23, 2012 8:20 pm
Ahhh nice one cleared it up.
I have a 9FSAY block.
I'll order studs not bolts.
PostPosted: Thu Aug 23, 2012 10:24 pm
Be careful ordering studs, that they are for an S motor... these locate the caps.
They make stud kits for 1100S etc too but they are different to Cooper S.
PostPosted: Thu Aug 23, 2012 10:34 pm
i used the ARP studs , just dont use the washers on the ends, and machine 4 mm off the stud.
you can see the washer and the length of the standard arp set up, no good so remove the washer and cut the sud down at the end that goes into the block
PostPosted: Fri Aug 24, 2012 9:37 am
Love your centre punch marks Dodge 8)
Users browsing this forum: Bing [Bot] and 79 guests
