77' Moke Differences ? https://www.ausmini.com/forums/viewtopic.php?f=2&t=78170 |
Page 1 of 2 |
Author: | _666_ [ Fri Aug 24, 2012 7:38 pm ] |
Post subject: | 77' Moke Differences ? |
as im new to the moke scene could someone tell me what is different between a 77' moke and a mini are there any subframe differences ? i know the rear wheel cylinders are larger ? 11/16" is there anything else ? sorry for all the questions |
Author: | thomas_hb [ Fri Aug 24, 2012 7:45 pm ] |
Between a '77 and what? |
Author: | _666_ [ Fri Aug 24, 2012 8:14 pm ] |
oops, between a 77'moke and a mini |
Author: | Harley [ Fri Aug 24, 2012 8:18 pm ] |
Well its a moke, so everythings different. ![]() |
Author: | thomas_hb [ Fri Aug 24, 2012 8:19 pm ] |
If this relates to the Sirion project, there is no substantial difference between subframes. The differences which exist are limited to bumper bar mounting options. I think any old mini subframe will go straight in. Trailing arms are different. Hrrrmmm, what else? I can't remember. Perhaps wheel hubs too? |
Author: | thomas_hb [ Fri Aug 24, 2012 8:20 pm ] |
Eg: my Moke has a subframe from a Deluxe or a K or some other late roundy. |
Author: | PDJ [ Fri Aug 24, 2012 8:21 pm ] |
If you drop the front subframe complete with engine, brakes, etc,, that is all Mini. Rack is the same, Headlights, Master Cylinder. If you drop the rear the rear arms are longer and not mini. Everything else if different, i.e. the body. ![]() |
Author: | _666_ [ Fri Aug 24, 2012 8:21 pm ] |
well if im going to pull the subframes appart and get them powder coated etc, i was going to buy kits for the trailing arms etc (if needed of course) and if i look for parts on minispares, they dont really stock "moke" parts but i was wondering if they are different to mini parts for this purpose know what i mean ? ![]() |
Author: | thomas_hb [ Fri Aug 24, 2012 8:22 pm ] |
Yeah, I know what you mean. I think from a subframe perspective you're fine. |
Author: | PDJ [ Fri Aug 24, 2012 8:24 pm ] |
_666_ wrote: well if im going to pull the subframes appart and get them powder coated etc, i was going to buy kits for the trailing arms etc (if needed of course) and if i look for parts on minispares, they dont really stock "moke" parts but i was wondering if they are different to mini parts for this purpose
know what i mean ? ![]() Just get Mini stuff, you'll be right ![]() |
Author: | Morris 1100 [ Fri Aug 24, 2012 8:24 pm ] |
The front frame is a Mini frame with a couple of add ons for bumper mounts and sump guard. |
Author: | _666_ [ Fri Aug 24, 2012 8:24 pm ] |
how about brakes, and perhaps even steering racks ? i intend to replace the front brakes with discs, and renew the rear.. |
Author: | PDJ [ Fri Aug 24, 2012 8:34 pm ] |
_666_ wrote: how about brakes, and perhaps even steering racks ?
i intend to replace the front brakes with discs, and renew the rear.. Brakes are mini. Racks are posted to Dr Mini ![]() |
Author: | drmini in aust [ Fri Aug 24, 2012 8:52 pm ] |
PDJ wrote: _666_ wrote: how about brakes, and perhaps even steering racks ? i intend to replace the front brakes with discs, and renew the rear.. Brakes are mini. Racks are posted to Dr Mini ![]() Mini King has rebuilt Oz racks for later Mokes, with Morris 1100 tierods on em. This gives a bit more thread engagement in the tierod ends. But really these are for the last of the Mokes which had funny steering arms; on a `77 either these or a std Mini rack should fit OK. |
Author: | John Smidt [ Fri Aug 24, 2012 9:46 pm ] |
drmini in aust wrote: PDJ wrote: _666_ wrote: how about brakes, and perhaps even steering racks ? i intend to replace the front brakes with discs, and renew the rear.. Brakes are mini. Racks are posted to Dr Mini ![]() Mini King has rebuilt Oz racks for later Mokes, with Morris 1100 tierods on em. This gives a bit more thread engagement in the tierod ends. But really these are for the last of the Mokes which had funny steering arms; on a `77 either these or a std Mini rack should fit OK. Also if you are fitting imported 8.4 disc brake assy S/H they often had steering arms that did not give You enough thread on Your tie rods When fitting the Tie rod Ends Front moke subframes As Morris 1100 Said Rear subframes are standard dry frames with some extra sheet metal bits welded on for extra strength |
