It is currently Tue Aug 12, 2025 1:40 am
PostPosted: Sun Oct 14, 2012 9:08 pm
As per the title any one got one handy..
Mines 7.15mm (used) and old one I fund in a pile of bits is 8.34mm
nothing in any of my books.
TA B
PostPosted: Sun Oct 14, 2012 9:15 pm
When you squeeze them with your fingers so the springy thingys inside are flat they measure about 7.5mm when new, I think.
Can double check one in the morning...
PostPosted: Thu Oct 18, 2012 6:18 pm
I forgot to reply to this earlier.
I measured 2 new clutch plates i have.
The first is a solid button clutch, which measures 7.25mm, So that has no springs between the plates
The second is an ap racing plate (normal type), which measured 7.4mm
PostPosted: Thu Oct 18, 2012 7:07 pm
Thanks I brought a new clutch kit and it measured 7.94mm uncompressed so they seem to vary in thickness.
The one I took of was 7.15mm compressed
Ta B
