Rod change to remote in clubman: whats involved? https://www.ausmini.com/forums/viewtopic.php?f=2&t=78379 |
Author: | SuperCooper [ Sat Sep 08, 2012 10:06 pm ] |
Post subject: | Rod change to remote in clubman: whats involved? |
Am thinking of swapping gboxes on my engine. Currently run an A+ box with 3.1 diff. Not happy with gear ratios, in particular 1st & 2nd, and want to swap to a 3.44 diff. I have a 4 synchro remote box with 3.44 dif. Would like to convert it to cooper s cr gear ratios and use it. So what's involved with putting it in a clubby? Rear remote housing bracket Do I need to swap driveshafts to accommodate the steel Uni joints? Anything else? Thanks. |
Author: | ryan [ Sun Sep 09, 2012 9:36 am ] |
You can run pot joints if you want. I just changed to pots in mine. |
Author: | 1310/71 [ Sun Sep 09, 2012 9:41 am ] |
depending on what year shell, you may also have to modify the hole in the floor slightly, to mount the rod change mechanism. |
Author: | d1ck0 [ Sun Sep 09, 2012 9:44 am ] |
1310/71 wrote: depending on what year shell, you may also have to modify the hole in the floor slightly, to mount the rod change mechanism.
I think he's wanting to go the other way - Rod change to Remote. Dicko. |
Author: | SuperCooper [ Sun Sep 09, 2012 4:41 pm ] |
Yes rod change ATM, switch to Remote in a 78 clubby Van. |
Author: | brett [ Sun Sep 09, 2012 10:15 pm ] |
You need a gearbox, the shift mechinism, remote gearstick and a bracket from a hydro car |
Author: | 1310/71 [ Mon Sep 10, 2012 7:44 am ] |
d1ck0 wrote: 1310/71 wrote: depending on what year shell, you may also have to modify the hole in the floor slightly, to mount the rod change mechanism. I think he's wanting to go the other way - Rod change to Remote. Dicko. Typo - thanks Dicko. I say that as the floor in my '71 clubman had to be modified to fit a rod change. Maybe the very early ones came out with remote? And yes, there was a typo in my original response, I meant mount a remote. |
