It is currently Thu Aug 14, 2025 2:04 am
 Post subject: Mk1 horn wire
PostPosted: Sun Sep 09, 2012 6:59 pm
The wire for the horn that runs through column on my mini has broken off short.
Is there an easy way to remove/reinstall these?
Ryan
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Sun Sep 09, 2012 8:04 pm
You'll need to take inner shaft out and the brss ring slides off with a little persuasion, then you'll see how it goes together. You'll have to make up a wire and reassemble it
Users browsing this forum: No registered users and 205 guests
