neally had an acco today https://www.ausmini.com/forums/viewtopic.php?f=2&t=7841 |
Author: | 998_Clubman [ Sun Jun 05, 2005 7:32 pm ] |
Post subject: | neally had an acco today |
well story goes i was driving along in the mini.. went to push the brakes and straight to the floor.. no feel to the pedal at all ![]() ![]() has this happened to anyone else before? |
Author: | aaron [ Sun Jun 05, 2005 7:58 pm ] |
i had that happen to me but it was the clutch. good bit of advice i got was to use Baby Nappy Bobby pins. There easy to get it and won't fall out. Just don't buy them when you girlfreind is around ![]() Cheers Aaron |
Author: | Morris 1100 [ Sun Jun 05, 2005 8:05 pm ] |
I had a Clubman with lousy brakes, the pedal was really low and after adjusting the brakes and then rebuilding them I found out that the pin was missing! The brakes worked but the pedal was nearly on the floor! |
Author: | Gordo [ Sun Jun 05, 2005 9:29 pm ] |
Ok so my brake pedal has fallen to the floor a couple of times before... Lucky for me it has not been a total lost of braking, pump it "SEVERAL" times finally gets the brakes to work. But on a more interesting subject a mini with a 5spd gearbox?? |
Author: | JC [ Sun Jun 05, 2005 10:04 pm ] |
Post subject: | Re: neally had an acco today |
998_Clubman wrote: has this happened to anyone else before?
Amongst other things I had a brake master cylinder fitted by a mini 'specialist' in Brisbane. Recently I pulled the brake M/C out to fit the twin line one. Needless to say I was less than impressed when there was no R clip holding the pin in there. Said mechanic also fitted non-locking, metric nuts to my steering rack ends. |
Author: | willy [ Sun Jun 05, 2005 10:10 pm ] |
Whitestriped63 wrote: Said mechanic also fitted non-locking, metric nuts to my steering rack ends.
![]() Dodgey people out there... non-mini specialist i suppose? |
Author: | Wolfman [ Sun Jun 05, 2005 10:13 pm ] |
Gordo wrote: But on a more interesting subject a mini with a 5spd gearbox??
It's powered by a Gti with a 5spd box, not an A series with a 4 speed ![]() |
Author: | Gordo [ Mon Jun 06, 2005 7:18 pm ] |
Ahh well that explains things a little... ![]() |
