It is currently Wed Aug 06, 2025 2:02 pm
 Post subject: wiring in a heater
PostPosted: Mon Sep 17, 2012 10:49 pm
Hi guys, just wondering cos the missus feels the cold real easy I've gotta put a heater in the mini. so the question is what do i need to do modify or add to put the heater in with out damaging the wires or anything like that?
Regards Kermit (TadPole)
PostPosted: Tue Sep 18, 2012 7:03 am
Well firstly youve got to add a heater tap to the head and run a hose from it to inside the cabin. Then you've also got to change your bottom radiator hose so it has a take off hose for the heater. These hoses both run inside the cabin through the holes in the passenger side bulkhead.
The heater tap has a wire which will need to be run into the dash somewhere.
The only wiring needed for the heater itself is a switch to turn the fan inside on and off.
Ive only ever dealt with clubman heaters and they are awfully large, so nowadays I just run a small fleece blanket for the passanger :lol:
