It is currently Sat Aug 09, 2025 11:35 pm
PostPosted: Thu Sep 13, 2012 8:34 pm
I just bought myself another mini - 1977 round nose , it would appear to be an 1100cc . One of the things i am most curious about is it has the 3 gauge clubman instrument cluster fitted to it - were these ever fitted to a round nose?? If it is not factory i may attempt to go back to the original cluster.
Here is what i found on the compliance plate - if anyone could give me some info that would be great!!
3/77
021X251N09/25668
1-2-3A-46-5B-6-7-8-10B-11-12-14-15-16-18-20-21-22A-23-24-25-27A-28-29-31-34
and the engine number is: 1015 10486
thanks guys!
PostPosted: Thu Sep 13, 2012 8:36 pm
Sounds like a roudy front welded into the body of a leyland mini s
PostPosted: Thu Sep 13, 2012 8:37 pm
I would be more concerned about why a 77 mini has a round nose! :shock:
PostPosted: Thu Sep 13, 2012 8:38 pm
77 Leyland Mini with a 74/75 1100 motor.
PostPosted: Thu Sep 13, 2012 8:40 pm
wow thats certainly different! I forgot to mention it also has the clubman switch panel where the fan / lights are etc, whatever u call it
PostPosted: Thu Sep 13, 2012 8:42 pm
Definitely a clubman...
hopefully you didnt get rorted on price paying for a roundy
What tail lights does it have?
Rounded or square?
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Thu Sep 13, 2012 8:45 pm
square! whoever converted it must of done it a long time ago as the previous owner was a youngin who let it go unlicensed, and by the looks of it, it hasnt been cleaned / painted / attended to in a very long time,
when you find old 1 and 2 c coins inside that gives you some idea lol
how hard is it to convert to the 3 guage roundy cluster?
PostPosted: Thu Sep 13, 2012 8:56 pm
The first thing i would do before planning anything with the car is have a look how the front was changed because if it was done by someone who had no clue they may have effected the structure
 Post subject: Roundy?
PostPosted: Fri Sep 14, 2012 6:17 am
Sounds like it had a front cut job. Get someone who knows Panel beating to check if it was done properly.
"Let us remove your "SHORTS"
PostPosted: Sat Sep 15, 2012 4:24 pm
Cluster conversion is fairly easy but the hard part is finding a 3 gauge cluster!
And then getting it for a reasonable price!
PostPosted: Sat Sep 15, 2012 5:34 pm
Don't forget, you will probably need to put a hole in the firewall behind the carby if you are going to put the Cooper S style gauges in there, unless it is an early cluby with the hole there already.
Users browsing this forum: watsupskip and 84 guests
