mini i picked up - need some info! https://www.ausmini.com/forums/viewtopic.php?f=2&t=78464 |
Author: | Ryan1980 [ Thu Sep 13, 2012 8:34 pm ] |
Post subject: | mini i picked up - need some info! |
I just bought myself another mini - 1977 round nose , it would appear to be an 1100cc . One of the things i am most curious about is it has the 3 gauge clubman instrument cluster fitted to it - were these ever fitted to a round nose?? If it is not factory i may attempt to go back to the original cluster. Here is what i found on the compliance plate - if anyone could give me some info that would be great!! 3/77 021X251N09/25668 1-2-3A-46-5B-6-7-8-10B-11-12-14-15-16-18-20-21-22A-23-24-25-27A-28-29-31-34 and the engine number is: 1015 10486 thanks guys! |
Author: | 123grosso [ Thu Sep 13, 2012 8:36 pm ] |
Sounds like a roudy front welded into the body of a leyland mini s |
Author: | Monaco [ Thu Sep 13, 2012 8:37 pm ] |
I would be more concerned about why a 77 mini has a round nose! ![]() |
Author: | Morris 1100 [ Thu Sep 13, 2012 8:38 pm ] |
77 Leyland Mini with a 74/75 1100 motor. |
Author: | Ryan1980 [ Thu Sep 13, 2012 8:40 pm ] |
wow thats certainly different! I forgot to mention it also has the clubman switch panel where the fan / lights are etc, whatever u call it |
Author: | sam_1100 [ Thu Sep 13, 2012 8:42 pm ] |
Definitely a clubman... hopefully you didnt get rorted on price paying for a roundy |
Author: | ryan [ Thu Sep 13, 2012 8:42 pm ] |
What tail lights does it have? Rounded or square? |
Author: | Ryan1980 [ Thu Sep 13, 2012 8:45 pm ] |
square! whoever converted it must of done it a long time ago as the previous owner was a youngin who let it go unlicensed, and by the looks of it, it hasnt been cleaned / painted / attended to in a very long time, when you find old 1 and 2 c coins inside that gives you some idea lol how hard is it to convert to the 3 guage roundy cluster? |
Author: | 123grosso [ Thu Sep 13, 2012 8:56 pm ] |
The first thing i would do before planning anything with the car is have a look how the front was changed because if it was done by someone who had no clue they may have effected the structure |
Author: | Convertible Mini [ Fri Sep 14, 2012 6:17 am ] |
Post subject: | Roundy? |
Sounds like it had a front cut job. Get someone who knows Panel beating to check if it was done properly. |
Author: | sam_1100 [ Sat Sep 15, 2012 4:24 pm ] |
Cluster conversion is fairly easy but the hard part is finding a 3 gauge cluster! And then getting it for a reasonable price! |
Author: | IndigoBlueCooperS [ Sat Sep 15, 2012 5:34 pm ] |
Don't forget, you will probably need to put a hole in the firewall behind the carby if you are going to put the Cooper S style gauges in there, unless it is an early cluby with the hole there already. |
