It is currently Mon Aug 11, 2025 12:23 am
 Post subject: remote oil sender?
PostPosted: Thu Sep 13, 2012 9:49 pm
hi guys
very simple one
I have this
Mini T piece oil fitting (use your oil light and mechanical gauge)
http://www.minisport.com.au/prod838.htm
so i run the dash oil switch & a mechanical gauge. so it is 'T'd'
I want to free up more room as it pokes out alot & fouls my front mount fan/rad combo im playing with.
what is the thread? going into the block? not sure what adapter to buy, should i use a brass thing? or shiny alloy thing?
do you think maybe just getting a right angled adapter & screwing into that would work ok? then screwing the fitting into that fitting.
should free up a heap?
PostPosted: Thu Sep 13, 2012 10:33 pm
Thread is 1/8" NPT
http://www.speedograph-richfield.com/html/oil_pipe_lines.html
PostPosted: Thu Sep 13, 2012 10:47 pm
Perfect thanks buddy :) make life easy to
Sort something.
You think if I put a right angle fitting and
Then screw Into that so it comes from
The side would be ok?
 Post subject: oil sender
PostPosted: Thu Sep 13, 2012 11:08 pm
hi
i wanted to put a pressure sender on and looked at T pieces, extenders etc but the oil line to the filter got in the way. Oil temp sender by itself, fits under the assembly. , when add extensions etc was going to stick out to far... so i went to hydraulic hose shop and got a remote fitting via braided hose. It is currently sitting on the inside of the grille near the coil. (will probably move it later) I thought the original thread was 1/8 BSP and the new Aftermarket fittings are 1/4 BSP not npt.
Cheers FNQ
Users browsing this forum: No registered users and 151 guests
