hi guys
very simple one
I have this
Mini T piece oil fitting (use your oil light and mechanical gauge)
http://www.minisport.com.au/prod838.htm
so i run the dash oil switch & a mechanical gauge. so it is 'T'd'
I want to free up more room as it pokes out alot & fouls my front mount fan/rad combo im playing with.
what is the thread? going into the block? not sure what adapter to buy, should i use a brass thing? or shiny alloy thing?
do you think maybe just getting a right angled adapter & screwing into that would work ok? then screwing the fitting into that fitting.
should free up a heap?
