New Clutch required? :-( https://www.ausmini.com/forums/viewtopic.php?f=2&t=78472 |
Author: | gibovski [ Fri Sep 14, 2012 12:30 pm ] |
Post subject: | New Clutch required? :-( |
I was out stuck in traffic yesterday in my 74 leyland S when my clutch started engaging lower and lower on the pedal and it became increasingly difficult to get into first while stationary and idling. By the time I got home pushing the clutch pedal in at idle was causing a loose rattling sound from the engine bay and a slight drop in idle revs. The clutch take up seems normal and there was no slipping or any other issues. The car has only done about 10,000kms since the clutch was rebuilt. Does anyone have any idea what could be going on here? I just spent money last month n new wheel cylinders and really don't want to spend any more right now... How much is a new clutch rebuild if required? |
Author: | awdmoke [ Fri Sep 14, 2012 1:09 pm ] |
Sounds more like your clutch master or slave cylinders are leaking. Check the fluid level & look for leaks. Note that the master cylinder can leak down inside the car so can be hard to spot. |
Author: | frednutz&co [ Fri Sep 14, 2012 5:13 pm ] |
check clearance on the screw thinghie on the wok (someone will know the correct terminoligy )ben at link adjusted mine last week as my gearchange was crook ![]() |
Author: | michaelb [ Fri Sep 14, 2012 7:02 pm ] |
Could be the bearing? |
Author: | simon k [ Sat Sep 15, 2012 7:15 pm ] |
sounds like a thrust bearing to me too - PM me if you want a replacement that will last |
