It is currently Tue Aug 05, 2025 11:20 pm
 Post subject: Leaky diff
PostPosted: Tue Sep 11, 2012 9:31 pm
Hi Guys, I got a bad leak from the passenger side diff seal.
What is the process for repair?
Pull out P/S drive shaft, remove that side casing and replace the seal?
Is it that easy?
And of course, recomended place of replaecment purchase from NW Melb
'63 850/1100 + more cooper goodies
 Post subject: Repair leak,
PostPosted: Tue Sep 11, 2012 10:54 pm
Don't forget to drain oil first.
"Let us remove your "SHORTS"
PostPosted: Mon Sep 17, 2012 8:20 pm
If the side plate bush is badly worn the new seal will flog out pretty quickly...
PostPosted: Tue Sep 18, 2012 6:11 am
However if you are just doing the seal, no need to remove side casing.
