wiring in a heater https://www.ausmini.com/forums/viewtopic.php?f=2&t=78521 |
Author: | Kermit [ Mon Sep 17, 2012 10:49 pm ] |
Post subject: | wiring in a heater |
Hi guys, just wondering cos the missus feels the cold real easy I've gotta put a heater in the mini. so the question is what do i need to do modify or add to put the heater in with out damaging the wires or anything like that? |
Author: | mini1990 [ Tue Sep 18, 2012 7:03 am ] |
Well firstly youve got to add a heater tap to the head and run a hose from it to inside the cabin. Then you've also got to change your bottom radiator hose so it has a take off hose for the heater. These hoses both run inside the cabin through the holes in the passenger side bulkhead. The heater tap has a wire which will need to be run into the dash somewhere. The only wiring needed for the heater itself is a switch to turn the fan inside on and off. Ive only ever dealt with clubman heaters and they are awfully large, so nowadays I just run a small fleece blanket for the passanger ![]() |
