It is currently Sun Jul 27, 2025 8:40 am
PostPosted: Tue Sep 18, 2012 3:38 pm
i need some steel brackets made up and i am not sure where to go.
Does anyone either have the ability or know somewhere that can do them for me??.
Here's a pic of what i need.
I need 6 of these.. ( measurements are in mm).
Dusk Blue
1964 850
 Post subject: Brackets
PostPosted: Tue Sep 18, 2012 3:53 pm
Tim,
Correct me if im wrong but wouldnt they just be 40 x 40mm (5mm) equal angle cut at 25mm long?
Just ask the steel merchant to put them on the saw?
Shane
PostPosted: Tue Sep 18, 2012 4:06 pm
Yep, that is a standard size as 40 x 40 x 5 angle.
If you need the square edge, use 45 or 50 x 50 x 5 angle and cut the tips back.
PostPosted: Tue Sep 18, 2012 4:18 pm
Oh, ok.
That should make it a bit easier.. :D
So if i just ring up a steel place, they should be able to help me out??
Dusk Blue
1964 850
PostPosted: Tue Sep 18, 2012 7:48 pm
And they will usually cut to your sizes and charge you a cutting fee
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Wed Sep 19, 2012 8:51 pm
Brisbane Metal Market would be the go for this.... They are on the top end of moss st at springwood. One of the very few steel shops that do cut lengths these days. If not i might have some spare at work. :)
PostPosted: Wed Sep 19, 2012 9:43 pm
Contact Archangel007. He had a heap of alloy seat brackets made up that may suit your needs.
PostPosted: Thu Sep 20, 2012 10:23 am
Cool, thanks for the help guys
Dusk Blue
1964 850
Users browsing this forum: No registered users and 121 guests
