Timbo wrote:
Yeah, I know.
![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif)
And if you look closely the vent hole is higher up, the corners are squared off on the top and the slot is wider.
They're also somewhere between 1/10th and 1/20th of the price, so I'm prepared to relax my policy on not compromising on quality.
I think They Look Great, It is easy to find fault in anything if You try, if you have a look at every single part you put on Your Mini, I dare say faults even very minor ones could be found, HOWEVER, When You look at the car as a whole it is a different matter and the overall apperance is very Good.
A lot of us like our car to be original, and Some people just do not get this
You will get people telling You that the Plastic one is better and it does not rust, But it
does not stop the thread on the master cylinder from rusting, I have had master cylinders with plastic caps fitted and great force was needed to remove the cap
These Days the replacement Master cylinders are zinc plated back in 1961 the were tin plated tin plating does little to stop Rust ( After a while tin Plating and Zinc plating is hard to tell apart
If You car had Tin Caps and You want tin caps Buy These
![Cool 8)](./images/smilies/icon_cool.gif)
