Different Headlinings............ https://www.ausmini.com/forums/viewtopic.php?f=2&t=78553 |
Author: | brett [ Thu Sep 20, 2012 10:58 pm ] |
Post subject: | Different Headlinings............ |
Hi guys, I refitted a headlining that was what I pulled out of the Cooper S when I stripped it. Apparently its the wrong one... What is correct for a Mk1 Cooper S 1968. First Pic is what is fitted.. And I pulled out. ![]() 2nd Photo came out of 1970ish Mini K ![]() 3rd photo is out of my Leyland mini ![]() I believe there is a 4th style. ( Early) does anyone have an original hoodlining from a car dating early 1968 CHeers |
Author: | brett [ Thu Sep 20, 2012 11:28 pm ] |
![]() This is from Morris1100s 67 Car... So I wonder where they changed over.... |
Author: | Goldbrocade_62 [ Fri Sep 21, 2012 6:24 am ] |
My 68 deluxe has got the one in the last picture as have most deluxes I've seen |
Author: | Bubbacluby [ Fri Sep 21, 2012 9:29 am ] |
I believe you are supposed to have no.3 I thinki newton commercial reproduce this pattern, not sure how accurate it is though. No 2 is clubman and GT and mini k and i believe mk 2 cooper s |
Author: | Panthersteve [ Fri Sep 21, 2012 9:33 am ] |
Bubbacluby wrote: I believe you are supposed to have no.3
No 2 is clubman and GT and mini k and i believe mk 2 cooper s I wouldn't think #3 would be correct, it is a later used material, like Brett said it is in his Leyland Mini. |
Author: | low n blown [ Fri Sep 21, 2012 12:32 pm ] |
The correct one is the one out of your 1100 I may know where to get some. It is not made in the off white and will have to be re-dyed to be white. PM me if you are interested |
Author: | phillb [ Fri Sep 21, 2012 2:54 pm ] |
Yes, This is the correct one. My late (Nov Dec?) 68 S still has the same one. It kind of has a wood-grain pattern. ![]() Interestingly the pattern of the visors with the little swirls is what they used in the UK for the headlining also, ie they matched. In aus they must have sourced a local fabric for the headliner but maybe continued to get the visors from the UK. |
Author: | drmini in aust [ Fri Sep 21, 2012 4:14 pm ] |
My 3/70 car had those same swirly pattern visors, no idea what the roof lining was though as it had none. ![]() |
Author: | Morris 1100 [ Fri Sep 21, 2012 4:31 pm ] |
brett wrote: ![]() This is from Morris1100's 67 Car... So I wonder where they changed over.... My car is a mid 68 one. |
Author: | Bubbacluby [ Fri Sep 21, 2012 5:04 pm ] |
Bubbacluby wrote: I believe you are supposed to have no.3 I thinki newton commercial reproduce this pattern, not sure how accurate it is though. No 2 is clubman and GT and mini k and i believe mk 2 cooper s Panthersteve wrote: Bubbacluby wrote: I believe you are supposed to have no.3 No 2 is clubman and GT and mini k and i believe mk 2 cooper s I wouldn't think #3 would be correct, it is a later used material, like Brett said it is in his Leyland Mini. Sorry Panther Steve your right, No 3 is definitely not right. I dont know what i was doing when i wrote that, I have no idea. I meant no. 4 (I cant count, sorry) I thought Newton commercial remade it, but i had a look and could only find the cream crackle style. The particular pattern you are after was also used in deluxe's Sorry about that. Brenton |
Author: | 68Rusty [ Fri Sep 21, 2012 7:41 pm ] |
Has anyone tried the SA minisport one. Is it a reasonable reproduction? http://www.minisport.com.au/prod955.htm |
