It is currently Tue Jul 22, 2025 1:43 am
 Post subject: Fuel tank leaking
PostPosted: Thu Sep 20, 2012 10:05 pm
I have a very very light fuel tank leak, must be a pin hole some where.
what is the best way to repair the van tank?
is there a additive i can pore in?
can some one link me?
lastly is it any good?
PostPosted: Thu Sep 20, 2012 10:58 pm
Products exist, never tried them.
Most are centred around an epoxy coating on the inside of the tank.
http://www.por15.com/FUEL-TANK-REPAIR-K ... info/FTRK/
PostPosted: Thu Sep 20, 2012 11:38 pm
I tried the soap trick! it worked lol.
grind some soap bar onto the leak
it stopped it from leaking, put some epoxy over the soap see what happens in the morning.
i think ill try this product out
http://www.kbs-coatings.com.au/kbs-auto ... sealer-kit
PostPosted: Fri Sep 21, 2012 7:00 am
KBS sealer worked a treat, had enough to seal two tanks .Watch for the small filter in the tank.
PostPosted: Fri Sep 21, 2012 3:22 pm
With the KBS and POR tank repair kits, be sure to move the whole tank around for the time specified to ensure the whole inside of the tank is coated.
Dont just pour it into the tank, whilst the tank was in the car like some people have! :shock:
PostPosted: Sat Sep 22, 2012 8:18 am
+ 1 KBS.
Used it on bike tanks and cars.
Good product. Easy to order and quick delivery in my case.
Kit comes with everything to treat/kill rust and clean tank.
As above follow instructions and will leave you trouble free for years to come.
Cheers Rob.
82 BJ42 just completed resto
64 850 Modified(about to start rebuild)
Users browsing this forum: Majestic-12 [Bot] and 97 guests
