It is currently Fri Jul 18, 2025 11:34 am
 Post subject: Spray can jobs
PostPosted: Mon Sep 24, 2012 5:56 pm
Got a couple of gloss black coats down on my flares when going a clear top coat should I sand between the last gloss black coat & top clear with 1200 grit or something?
Spay cans. Acrylic .
PostPosted: Mon Sep 24, 2012 8:21 pm
My painter says no! Rub the clear coat.
However, as the black is a solid color, you should not need to clear coat it?
if you sand it will give you a flater (less orange peal)finish. if your coulor is solid (non metalc or pearl)you dont need cleae coat it is mainly to protect these finishes. just rub with 1200 and then 2000 and then cut with cuting compound and final pollish would do the jop perfectly
PostPosted: Mon Sep 24, 2012 8:28 pm
I'd still clear it so it stays fresh looking and scratches won't be a drama as its the clear coat that gets it first. Will look smoother with a few coats of clear too. But don't sand before the clear lightly sand the clear between coats for that smooth no orange peel finish.
If its got tits or wheels its gonna cost you
1973 Solid side Leyland Mini Panelvan 1100 in Hairy Lime(Elma)
1976 Clubby project in progress
1966 Morris Mini Deluxe in need of a full resto
1971 Mini K Garden Art
