Kennomini wrote:
The uni joints are the correct ones for the matic. They are the same as the Cooper S uni joints.
I see this joint being much much better than the pot joints or the rubber uni joints.
They are more compact/neater, dry so they don't need a sealed rubber boot, and they also look much cheaper. Are their any draw backs to these compared to the other joints?
The U/Js inside them are cheap to replace, sure, but the 2 drive yokes are expensive new, so is the drive flange and diff output shaft if needed.
Apart from autos they were only used on Cooper S AFAIK, so they didn't make millions like they did the rubber U/Js and pot joints.
They are stronger than a pot joint.
I like em, I use on both my motors/cars.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
