Weird electrical/starting issue https://www.ausmini.com/forums/viewtopic.php?f=2&t=78611 |
Author: | doogie [ Tue Sep 25, 2012 5:02 pm ] |
Post subject: | Weird electrical/starting issue |
The clubman im working on at the moment is doing my head in, when i turn the key to start the solenoid powers up, as soon as i crank it over the power goes away, flick the key back and the powers back, i've changed the solenoid but it still does the same, the motor & ignition switch are out of another car but worked perfectly before this. Any suggestions to what it could be? Doogie |
Author: | poeee [ Tue Sep 25, 2012 5:23 pm ] |
Swapped the starter motor? |
Author: | miniDave [ Tue Sep 25, 2012 6:29 pm ] |
Earthing strap from engine to body? Check there is no paint on the clutch housing where the stater motor bolts in. |
Author: | drmini in aust [ Tue Sep 25, 2012 7:02 pm ] |
If it's cranking over but not firing, I had that problem last year. ignition switch mate. ![]() it's dropping power to the coil during cranking. To prove it, hotwire the coil then turn the key. |
Author: | mini_mad_matt [ Tue Sep 25, 2012 7:15 pm ] |
I had this same problem when i put megajolt on my car. I powered it all from the fuse box, which turns out would lose power when the key was turned to cranking. So i hot wired it and it worked fine. It was really weird though, because how was it starting before? The wiring on the car is a mess so i guess the coil was wired up some funny way, but i now have a new switch to put in as the old one was always dicky. |
Author: | drmini in aust [ Tue Sep 25, 2012 7:42 pm ] |
What happens is when the ign switch contacts get worn, the white output wire to the switched fuse loses power when you turn key to crank. |
Author: | norton [ Tue Sep 25, 2012 7:54 pm ] |
either a stuffed battery or a crook connection |
Author: | doogie [ Tue Sep 25, 2012 8:03 pm ] |
Battery is fine, cranks over easily, earth strap has a good earth, but the weird thing is that the steering coloum/ignition came out of a driving running car, i'll put another in tomorrow and see if that cures the problem. Doogie |
Author: | goodie [ Tue Sep 25, 2012 8:49 pm ] |
I'm with Doc , i would try another ignition switch , i have seen this happen twice now , ie; engine would continue to wind over without firing whilst holding key in the start position , but as soon as you release the key , engine would fire up . |
Author: | drmini in aust [ Tue Sep 25, 2012 9:52 pm ] |
As I said before, to test you can hotwire the coil, or else put a meter on the coil's + terminal whilst cranking and see whatcha got. My bet is 0V.. |
Author: | doogie [ Wed Sep 26, 2012 5:38 pm ] |
Put another ignition in it, still the same problem, ignition side of the fuse box loses power when the starter is cranking, i think a match might fix the problem!!! Doogie |
Author: | Monaco [ Wed Sep 26, 2012 6:51 pm ] |
doogie wrote: i think a match might fix the problem!!!
Doogie ![]() For all I know, it could be a dodgy flux capacitor? Try wacking 2.21 gigawatts into it.....it works on tv! Good luck! |
