What are these numbers https://www.ausmini.com/forums/viewtopic.php?f=2&t=78654 |
Page 1 of 2 |
Author: | 64cooper [ Fri Sep 28, 2012 7:17 pm ] |
Post subject: | What are these numbers |
Whilst fitting the water pump to my recently rebuilt 65 Deluxe 998cc motor, I noticed these numbers (YY8228) stamped into the block. Any ideas? ![]() |
Author: | Kennomini [ Fri Sep 28, 2012 7:34 pm ] |
What area of the block is that? |
Author: | John Smidt [ Fri Sep 28, 2012 8:35 pm ] |
Have a look at Your Main bearing caps they should have the same numbers stamped on each cap |
Author: | 64cooper [ Sat Sep 29, 2012 8:44 am ] |
Thanks John, wish I could but the motor is now assembled, minus the head, and ready to go back in. I've had this motor for over forty years and it is the first time I have ever seen those numbers stamped near the water pump. I have now learnt something new about our venerable little cars. |
Author: | John Smidt [ Sat Sep 29, 2012 9:23 am ] |
64cooper wrote: Thanks John, wish I could but the motor is now assembled, minus the head, and ready to go back in. I've had this motor for over forty years and it is the first time I have ever seen those numbers stamped near the water pump. I have now learnt something new about our venerable little cars.
Thank You, It is a handy thing to know |
Author: | Flute [ Sat Sep 29, 2012 10:24 am ] |
Do they all have this? Why would you need to know the bearing cap number from the outside? |
Author: | drmini in aust [ Sat Sep 29, 2012 10:58 am ] |
Flute wrote: Do they all have this? Why would you need to know the bearing cap number from the outside?
Mains caps are not interchangeable from block to block once machined, so they had to stamp it on the block somewhere. BMC/BL just chose to stamp it on the front of block, up the top RH corner. Other cars are usually stamped on the bottom flange... |
Author: | John Smidt [ Sat Sep 29, 2012 11:16 am ] |
Yes Every Mini Block I have ever checked Has a number stamped there They are stamped there so that when an engine is being put together, You can check that the correct caps are fitted. to the correct block The reason they are stamped there is it is a nice flat area, so stamp is clear, and not in a position to be de faced often |
Author: | sitnlo62 [ Sat Sep 29, 2012 8:02 pm ] |
Interestingly, I have seen one Cooper S block with the Main cap number stamped on the pad where the fuel pump would mount, Was puzzled when I couldn't find it in the normal place,above and to the right of the water pump, so went looking for it.... Dave |
Author: | FNQ [ Sat Sep 29, 2012 9:00 pm ] |
Post subject: | caps not with block |
so if caps are not with block , what are the options please, cheers |
Author: | Morris 1100 [ Sat Sep 29, 2012 9:12 pm ] |
Paperweight Doorstop Anvil |
Author: | FNQ [ Sat Sep 29, 2012 9:35 pm ] |
Post subject: | doorstop |
thanks |
Author: | Morris 1100 [ Sat Sep 29, 2012 9:46 pm ] |
Seriously, the block is pretty much useless with the wrong caps. You can get it machined for a lot of money but then you will run into problems with the timing chain. Try to get the matching caps for that block or get another block with caps. |
Author: | FNQ [ Sun Sep 30, 2012 8:31 am ] |
Post subject: | main caps |
Luckily i haven't bought a block without caps). My non mechanical mind was trying to reconcile the availability of high end replacement main caps such as http://www.swiftune.com/Product/1000/swiftune-steel-main-cap-set-1300-mini-4-bolt-centre.aspx , given the block and caps are matched. Again , I don't have any experience or knowledge in engine rebuilds, but i guess throwing big money at something can offer partial solutions. Cheers |
Author: | Morris 1100 [ Sun Sep 30, 2012 4:26 pm ] |
Post subject: | Re: main caps |
FNQ wrote: Luckily i haven't bought a block without caps). My non mechanical mind was trying to reconcile the availability of high end replacement main caps such as http://www.swiftune.com/Product/1000/swiftune-steel-main-cap-set-1300-mini-4-bolt-centre.aspx , given the block and caps are matched.
Again , I don't have any experience or knowledge in engine rebuilds, but i guess throwing big money at something can offer partial solutions. Cheers It certainly is an option and it can be done. It is not cheap though. |
