What's happened? https://www.ausmini.com/forums/viewtopic.php?f=2&t=78668 |
Author: | mogadon [ Sun Sep 30, 2012 4:29 pm ] |
Post subject: | What's happened? |
Hi, Very new to my mini and cars in general. Can anyone help me out with what this and what might have happened? Cheers, Mog ![]() |
Author: | mogadon [ Sun Sep 30, 2012 4:35 pm ] |
Ok, so my image posting attempt failed ... will try something else |
Author: | Panthersteve [ Sun Sep 30, 2012 4:40 pm ] |
Looks like your heater tap is cactus and leaking coolant out. By the way, your problem posting the pic is probably that you have the "Disable BBCode in this post" box checked in your message editing box by default. You should be able to go back to your first post, click edit, uncheck the box, press submit anbd all should be good. Cheers Steve |
Author: | The Duckmeister [ Sun Sep 30, 2012 11:40 pm ] |
Panthersteve wrote: By the way, your problem posting the pic is probably that you have the "Disable BBCode in this post" box checked in your message editing box by default.
You should be able to go back to your first post, click edit, uncheck the box, press submit anbd all should be good. Cheers Steve More correctly, there is too much "stuff" in the link code. Cut off everything after the .jpg & post what's left between the image tags. Then your pic will show. ![]() |
Author: | Morris 1100 [ Sun Sep 30, 2012 11:47 pm ] |
Author: | Panthersteve [ Sun Sep 30, 2012 11:48 pm ] |
The Duckmeister wrote: Panthersteve wrote: By the way, your problem posting the pic is probably that you have the "Disable BBCode in this post" box checked in your message editing box by default. You should be able to go back to your first post, click edit, uncheck the box, press submit anbd all should be good. Cheers Steve More correctly, there is too much "stuff" in the link code. Cut off everything after the .jpg & post what's left between the image tags. Then your pic will show. ![]() Try again That doesn't work either ![]() |
