It is currently Wed Jul 30, 2025 2:03 am
 Post subject: What's happened?
PostPosted: Sun Sep 30, 2012 4:29 pm
Hi,
Very new to my mini and cars in general.
Can anyone help me out with what this and what might have happened?
Mog
'64 Mini Cooper 997
PostPosted: Sun Sep 30, 2012 4:35 pm
Ok, so my image posting attempt failed ... will try something else
'64 Mini Cooper 997
PostPosted: Sun Sep 30, 2012 4:40 pm
Looks like your heater tap is cactus and leaking coolant out.
By the way, your problem posting the pic is probably that you have the "Disable BBCode in this post" box checked in your message editing box by default.
You should be able to go back to your first post, click edit, uncheck the box, press submit anbd all should be good.
Steve
1964 998cc Cooper
1971 Mini K x 2
1972 Clubman GT
PostPosted: Sun Sep 30, 2012 11:40 pm
Steve
More correctly, there is too much "stuff" in the link code. Cut off everything after the .jpg & post what's left between the image tags. Then your pic will show. :)
PostPosted: Sun Sep 30, 2012 11:47 pm
PostPosted: Sun Sep 30, 2012 11:48 pm
Steve
Try again
That doesn't work either
1964 998cc Cooper
1971 Mini K x 2
1972 Clubman GT
