It is currently Mon Aug 11, 2025 12:26 am
PostPosted: Wed Oct 03, 2012 1:54 pm
Hi
Reading a fellow member's misfortunes due to a poorly calibrated torque wrench ( commiserations) picqued my interest.
Torque settings - Are these derived from mathematical formulas, settings based on metals/thickness used , trial and error, etc - how does the factory produce the specs? Interest value only Cheers
PostPosted: Wed Oct 03, 2012 1:59 pm
There are recommended maximum torque figures for all threaded fasteners- based on thread size form & pitch, and fastener's steel spec.
The material it is threaded into (eg steel or alloy) varies the torque figure that can be applied.
PostPosted: Wed Oct 03, 2012 3:47 pm
Torque settings are found from a combination of the bolts size and the preload required for the joint, which itself is found from a combination of the thread stress area, the bolts proof strength (eg a 10.9 bolt has a proof strength of 830Mpa) all multiplied by a certain preload factor eg 0.75.
 Post subject: torqued
PostPosted: Wed Oct 03, 2012 3:59 pm
excellent answers thank you
Users browsing this forum: Majestic-12 [Bot] and 145 guests
