It is currently Wed Aug 06, 2025 2:29 am
 Post subject: Off accellerator clunk..
PostPosted: Tue Oct 02, 2012 8:30 am
So if I lift of the accellerator in the 1275LS at 80 or more I get a distinct clunk through the car. I am not sure if it is drivetrain because it sometimes seems to go right through the car so I wondered if it might be engine mounts. I'll have a look at the weekend but any ideas?
I haven't noticed it before so it is a new issue.
Alec
PostPosted: Tue Oct 02, 2012 8:33 am
Check steady bar (dogbone) bushes, top steady mount face of firewall (these crack), engine mounts, also that the CV nuts are both still tight...
PostPosted: Tue Oct 02, 2012 8:41 am
Check ball joints too, though they normally make sounds at slower speeds.
PostPosted: Tue Oct 02, 2012 4:52 pm
I had the same problem with my car.
The steady bar opposite the brake and clutch cylinder was missing its nut and the one closest to the radiator was missing 1 of the 3 bolts that bolt into the firewall and missing 1 nut.
I fixed it all up and no more clunking :)
http://www.flickr.com/by_dan
2014 Land Rover Defender 90
PostPosted: Tue Oct 02, 2012 5:24 pm
I had this once as well in the Moke and it was a can of coke rolling forwards and backwards under the passenger seat :roll:
PostPosted: Tue Oct 02, 2012 6:19 pm
What bushes do you have in the engine steady bars , Neoprene or rubber ?
I have used both and the rubber bushes are much less harsh as far as vibration resonating back thru the car, and last longer .
Matty Read apparently sells a good quality rubber bush .
PostPosted: Tue Oct 02, 2012 8:13 pm
Rubber.
Thanks guys. Will have a look.
Alec
