Off accellerator clunk.. https://www.ausmini.com/forums/viewtopic.php?f=2&t=78688 |
Author: | 1275LS [ Tue Oct 02, 2012 8:30 am ] |
Post subject: | Off accellerator clunk.. |
So if I lift of the accellerator in the 1275LS at 80 or more I get a distinct clunk through the car. I am not sure if it is drivetrain because it sometimes seems to go right through the car so I wondered if it might be engine mounts. I'll have a look at the weekend but any ideas? I haven't noticed it before so it is a new issue. |
Author: | drmini in aust [ Tue Oct 02, 2012 8:33 am ] |
Check steady bar (dogbone) bushes, top steady mount face of firewall (these crack), engine mounts, also that the CV nuts are both still tight... |
Author: | Harley [ Tue Oct 02, 2012 8:41 am ] |
Check ball joints too, though they normally make sounds at slower speeds. |
Author: | danny_ [ Tue Oct 02, 2012 4:52 pm ] |
I had the same problem with my car. The steady bar opposite the brake and clutch cylinder was missing its nut and the one closest to the radiator was missing 1 of the 3 bolts that bolt into the firewall and missing 1 nut. I fixed it all up and no more clunking ![]() |
Author: | IwannaMini [ Tue Oct 02, 2012 5:24 pm ] |
I had this once as well in the Moke and it was a can of coke rolling forwards and backwards under the passenger seat ![]() |
Author: | goodie [ Tue Oct 02, 2012 6:19 pm ] |
drmini in aust wrote: Check steady bar (dogbone) bushes, top steady mount face of firewall (these crack), engine mounts, also that the CV nuts are both still tight...
What bushes do you have in the engine steady bars , Neoprene or rubber ? I have used both and the rubber bushes are much less harsh as far as vibration resonating back thru the car, and last longer . Matty Read apparently sells a good quality rubber bush . |
Author: | 1275LS [ Tue Oct 02, 2012 8:13 pm ] |
goodie wrote: drmini in aust wrote: Check steady bar (dogbone) bushes, top steady mount face of firewall (these crack), engine mounts, also that the CV nuts are both still tight... What bushes do you have in the engine steady bars , Neoprene or rubber ? I have used both and the rubber bushes are much less harsh as far as vibration resonating back thru the car, and last longer . Matty Read apparently sells a good quality rubber bush . Rubber. Thanks guys. Will have a look. |
