It is currently Wed Aug 13, 2025 9:43 am
 Post subject: Brake cylinder types
PostPosted: Tue Oct 02, 2012 7:53 pm
G'day guys,
So I put the mini in to get a new exhaust (at the local wheel, exhaust and and brake shop), no problem all done. Then while it was there I got them to do a wheel alignment, no problem all done. Then I thought might as well get them to make sure the brakes were sweet. problem.
They said I need new wheel cylinders, and I should replace all 6 (4 front, 2 back), no probs, i want my brakes to be perfect. so i said leave it to me and i'll organise parts. I ordered them in from Karcraft and gave to them this arvo.
They gave me a call saying they are the wrong ones, the locating pin is on the wrong side or something. I asked if they could just drill a hole to make them fit as someone had suggested somewhere before, but they said no, and wanted to use some they had ordered in (cost of 3 times what i paid from Karcraft).
Does anyone know what the differences between the different types?
PostPosted: Tue Oct 02, 2012 7:58 pm
Give Ash some flowers Nick .
the 5/8th rear wheel cylinders have the locating pin on the opposite to the 3/4 cylinders.
3/4" rear cylinders were used on drum all 'round minis, 5/8" rear cylinders were used on disc brake front cars (generally this is the case).
I am assuming that you have drums front and rear if they want you to replace all '6' of them? Are you sure you ordered 3/4" ones?
<edit> I recently drilled my brake backplates for 5/8" cylinders instead of 3/4" cylinders - so it is doable on the car. You don't want to reduce your brakes on a drum car so make sure you keep it as a matched set i.e. 3/4" cylinders with drums on the front as well.
PostPosted: Tue Oct 02, 2012 8:07 pm
I have found that the locating pins are different depending on the brand of wheel cylinder.
I usually change them every 18 months to 2 years and the locating holes can either be opposite or slightly offset to the original. :?
But yes make sure the diameter is correct because there are so many different types made over the years
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Tue Oct 02, 2012 8:12 pm
wow, fast reply thanks heaps..
yes drum brakes front and back.
I just checked the invoice (parts still at brake place):
Here is what i was got (well invoiced for anyway, dont have them here to check):
Brake Wheel Cyl - Mini (RHF) 15/16"
Brake Wheel Cyl - Mini (LHF) 15/16"
Brake Wheel Cyl - Mini(Rear) .750"
Should these be ok?
PostPosted: Tue Oct 02, 2012 8:15 pm
Another way to do it if you have a bench drill or milling machine is mark & drill another 5/32" blind hole accurately in the slave cylinder, then swap the pin over.
PostPosted: Tue Oct 02, 2012 8:16 pm
Yes cylinder sizes sounds OK
GWC127. LHF. 15/16"
Rear GWC1102/1 .750"
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Tue Oct 02, 2012 8:18 pm
Ask Karcraft for a catalogue as it has a lot of this info. Tim should be able to email you the PDF version
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Tue Oct 02, 2012 8:22 pm
GWC127. LHF. 15/16"
Ok sounds like i shoudl be able get them to fit (ie dont have to go their parts that are 3 times as much).
Might just get the mini home and do it myself.
PostPosted: Wed Oct 03, 2012 8:44 am
Just let the place know, i'm going to get the mini picked up and i'll do myself.
I have a couple workshop manuals i'll follow, but does anyone have any tips when installing the new cylinders and setting them up?
 Post subject: Brake Cylinders
PostPosted: Wed Oct 03, 2012 5:36 pm
If someone can tell me how to attach a MS Word file I am sure I can answer all your questons about brake cylinders
John Sneddon
0408 431 807
1963 Morris Cooper
1965 Morris 850
1968 Morris Cooper S
 Post subject: Re: Brake Cylinders
PostPosted: Wed Oct 03, 2012 6:42 pm
John, in short you can't attach a word file. In long, you could sign up to Rapidshare and upload it there and provide the link to the file on the forum here.
Check out the drum to disc conversion I did - this briefly touched on the rear wheel cylinders: http://www.ausmini.com/forums/viewtopic.php?t=77858
Users browsing this forum: No registered users and 222 guests
