It is currently Tue Aug 12, 2025 1:35 pm
PostPosted: Fri Oct 19, 2012 5:45 pm
Has anyone modified a manual subframe to take a auto engine?
I have a very bent auto frame but a good auto engine so I want to try and make something that works as the factory intended.
PostPosted: Fri Oct 19, 2012 6:03 pm
I would be tempted to straighten the bent auto one... or else cut the sides out and weld them into a manual one.
There is quite a difference in width.
The front rail is curved for clearance, but you could bend up a bit of RHS tube or pressed channel to replace that.
PostPosted: Fri Oct 19, 2012 8:46 pm
I've seen it done, but it looked like a total hatchet job. Better to start with an Auto subframe IMHO. Even a Rover one can be adapted to an Aussie Mini.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
Users browsing this forum: 68+86auto, cgo and 247 guests
