breather..........
https://www.ausmini.com/forums/viewtopic.php?f=2&t=78875
Author:  Blunder [ Thu Oct 18, 2012 11:06 pm ]
Post subject:  breather..........
Left(drivers) side of the engine bay the is a breather on my a+ 1275, whats if for??
it has a pipe fitting connected with one of the anodised breathers remotely mounted,,, reason i ask is the pipe fitting(engine0 is leaking oil at the connection where it bolts on
Author:  drmini in aust [ Fri Oct 19, 2012 1:40 pm ]
It is a crankcase breather, originally it was connected to the vac port on the side of the SU carby.
There is/was a steel gauze flame trap inside it, either that is blocked with crud (very common on old motors) or the blingy anodized filter is.
If the gauze is blocked, pull it out the bottom and replace with a S/S woven pot scrubber from Woollies or Coles. Perfect fit... 8)
