It is currently Sun Aug 17, 2025 7:11 pm
PostPosted: Sun Oct 21, 2012 5:40 pm
So, I am having a 1380 built up with an a plus box bolted to the bottom.
I had purchased a lightened and balanced pre verto clutch setup of a fellow member for the build.
I have now been recommended to go verto on this gearbox.
I was suggested early clutch plate wear may be a result of the pre verto on the A+ box.
Now I'M very hesitant to change. I think I was correct and my clutch choice will be fine.
Btw its an orange dot diaphragm with a next to new clutch plate.
I havent heard much good about verto's.
Opinions?
PostPosted: Sun Oct 21, 2012 6:04 pm
There is nothing special about an A+ box that makes it require a Verto clutch.
IMO non Verto clutches are better because:
1. The whole flywheel assembly can be lighter.
2. You can choose from blue , orange, grey, or double grey dot diaphragms.
3. They are way cheaper, the price of new Verto stuff is ridiculous.
4. Verto stuff is rare in Australia (Rovers & Metros never sold here).
The only benefit of a Verto clutch in a Mini IMO is less pedal pressure, as it has a `conventional' automotive style pressure plate with fingers in it..
PostPosted: Sun Oct 21, 2012 7:24 pm
I have an A+ box and block and run a pre verto clutch no problem.
Been in there for 4 years.
Just make sure it gets set up correctly if it's been lightened.
Now with 2 extra ports!
PostPosted: Sun Oct 21, 2012 7:26 pm
Cheers guys.
Choice confirmed.
