It is currently Sat Aug 16, 2025 10:13 pm
PostPosted: Sun Oct 21, 2012 3:31 pm
Can anybody help me with the width of the spacer in the swivel hub
Between the inside Bearing and the inside Grease seal
It would appear I now have to make 1 after I have lost 1 of mine.
Cheers Jim :D
PostPosted: Sun Oct 21, 2012 4:57 pm
The spacer width for drum brake hubs (ball bearings) is 0.094" (2.38mm)
The one for disc hubs (Timken bearings) is 0.229" (5.81mm) thick
If fitting Timkens into a drum brake hub you should fit the wider spacer, or the seal will hit the bearing inner cone.
PostPosted: Sun Oct 21, 2012 5:15 pm
Thanks Doc
Back to the shed for me. :D
Users browsing this forum: No registered users and 315 guests
