Front Disc Seal spacer Width
https://www.ausmini.com/forums/viewtopic.php?f=2&t=78901
Author:  Klaery [ Sun Oct 21, 2012 3:31 pm ]
Post subject:  Front Disc Seal spacer Width
Can anybody help me with the width of the spacer in the swivel hub
Between the inside Bearing and the inside Grease seal
It would appear I now have to make 1 after I have lost 1 of mine.
Cheers Jim :D
Author:  drmini in aust [ Sun Oct 21, 2012 4:57 pm ]
The spacer width for drum brake hubs (ball bearings) is 0.094" (2.38mm)
The one for disc hubs (Timken bearings) is 0.229" (5.81mm) thick
If fitting Timkens into a drum brake hub you should fit the wider spacer, or the seal will hit the bearing inner cone.
Author:  Klaery [ Sun Oct 21, 2012 5:15 pm ]
Thanks Doc
Back to the shed for me. :D
