It is currently Thu Aug 14, 2025 4:55 am
 Post subject: Hydro pump valve
PostPosted: Wed Oct 24, 2012 5:58 pm
Where do I get a hydrolastic pump bleed valve/fitting for my pump
I have lost the fitting that pumps the hydro system up in the car
Les
PostPosted: Wed Oct 24, 2012 6:17 pm
local tyre places should be able to get them for u just go ask for a tyre tractor fill valve the ones that put water into the tyres they r about 50 bucks
 Post subject: hydro valve
PostPosted: Wed Oct 24, 2012 6:40 pm
Just found the correct one,
the part number is
Schrader 2755
Thanks for your reply
Alpine Mountains full of Mini's and Moke's.
PostPosted: Thu Oct 25, 2012 10:07 pm
Apologies for the thread hijack.
I'm looking to get my wet subframe blasted and need to strip it.
To remove this filler/splitter from the subframe what is the nut size?
Is it 13/16, 7/8 or 15/16? Any tricks to getting it out?
Justin
 Post subject: hydro valve nut size
PostPosted: Fri Oct 26, 2012 8:58 am
The six sided hydro pipe nut is 3/4 AF
The thin six sided nut on the valve is 13/16 AF
you will need a deep socket,
wire brush the long thread first, then spray on a bit of lube, WD40
it then should unscrew ok,
Les
PostPosted: Fri Oct 26, 2012 9:08 am
Cool, thankyou.
Justin
PostPosted: Fri Oct 26, 2012 11:26 am
I think I used a spark plug socket with the cushioning removed
Users browsing this forum: Bing [Bot] and 310 guests
