Hydro pump valve
https://www.ausmini.com/forums/viewtopic.php?f=2&t=78939
Author:  ALPINE MOKE [ Wed Oct 24, 2012 5:58 pm ]
Post subject:  Hydro pump valve
Where do I get a hydrolastic pump bleed valve/fitting for my pump
I have lost the fitting that pumps the hydro system up in the car
Les
Author:  i got a mini [ Wed Oct 24, 2012 6:17 pm ]
local tyre places should be able to get them for u just go ask for a tyre tractor fill valve the ones that put water into the tyres they r about 50 bucks
Author:  ALPINE MOKE [ Wed Oct 24, 2012 6:40 pm ]
Post subject:  hydro valve
Just found the correct one,
the part number is
Schrader 2755
Thanks for your reply
Author:  jubblies [ Thu Oct 25, 2012 10:07 pm ]
Apologies for the thread hijack.
I'm looking to get my wet subframe blasted and need to strip it.
To remove this filler/splitter from the subframe what is the nut size?
Is it 13/16, 7/8 or 15/16? Any tricks to getting it out?
Author:  ALPINE MOKE [ Fri Oct 26, 2012 8:58 am ]
Post subject:  hydro valve nut size
The six sided hydro pipe nut is 3/4 AF
The thin six sided nut on the valve is 13/16 AF
you will need a deep socket,
wire brush the long thread first, then spray on a bit of lube, WD40
it then should unscrew ok,
Les
Author:  jubblies [ Fri Oct 26, 2012 9:08 am ]
Cool, thankyou.
Author:  Goldbrocade_62 [ Fri Oct 26, 2012 11:26 am ]
I think I used a spark plug socket with the cushioning removed
