odd leak on diff...
https://www.ausmini.com/forums/viewtopic.php?f=2&t=78957
Author:  Blunder [ Fri Oct 26, 2012 12:02 am ]
Post subject:  odd leak on diff...
hi guys..
I have an A+ 1275 that has been fitted with the old hardy spicer type inner joints seems to have an odd leak...
Seems to be leaking out of the centre of the diff output.... is that possible?? I can see there is a bolt and locking pin in the assembly.. is there a seal in there>?
Author:  drmini in aust [ Fri Oct 26, 2012 9:58 am ]
Common problem.
There is a rubber seal in there (literally a thick rubber washer, like the 2 in top of the rocker cover) but the oil rots the rubber and then they leak.
Also the ones some places supply now are too thick and tear up when the bolt is tightened.:x
I made my last ones out of lurethane, and applied some silastic as well.
Author:  Blunder [ Mon Oct 29, 2012 12:26 am ]
is this a simple case of undo the uni, remove the split pin,undo the nut and replace seal/grommet thing....??
Author:  drmini in aust [ Mon Oct 29, 2012 6:48 am ]
If there is a split pin and nut they are NOT Cooper S `Hardy Spicer' output shafts, but aftermarket drive flanges fitted to early (rubber uni) output shafts.
Hardy Spicers have a bolt and washer.
Early ones can leak, there's no seal in there, I put silastic on the splines before fitting the nut.
Author:  Blunder [ Fri Nov 02, 2012 4:12 pm ]
ok, took apart said uni joint and removed the split pin to find the nut just tight. Removed and put silastic on.... tighten and found that tight is about 3mm too far round so had to back of 1/8th of a turn too insert pin...
Did that last night.... STILL LEAKING..
Is there a shim? Might change the external seal next... that require removing the side cover?
Author:  drmini in aust [ Fri Nov 02, 2012 6:14 pm ]
Don't remove the side cover unless the bush in it is stuffed (tug the drive flange up and down to see).
You can change the seals in the car but drain the oil first. :P
If you do take it off, note the shims behind the LH one and put back the same, but BEWARE the gaskets they sell now are too damned thick (~.015") and thus you need extra shims. I put a .010" one behind the RH cover for a start...
It is bloody hard to shim it right when it's in the car; I'd change the seals if needed and leave the side cover bushes until the motor is out.
Author:  mini_mad_matt [ Fri Nov 02, 2012 6:17 pm ]
Replacing the side cover oil seal does not require removing the side cover. And it sounds like your uni joints are the rubber uni type ones. They use the same seal as pot joints, but cooper S hardy spicer joints use a different seal.
The diff seals commonly leak, especially when the diff is worn out and the side cover bush, allowing the yoke to flop about.
As for the nut, once you torque it up, you should do it up tighter to get the split pin in. But if it is so far out that it would be stupid to do it up that much, then try a different thickness washer behind the nut.
