Rear Adjustable Camber Brackets https://www.ausmini.com/forums/viewtopic.php?f=2&t=79007 |
Author: | 1018cc [ Mon Oct 29, 2012 11:10 pm ] |
Post subject: | Rear Adjustable Camber Brackets |
Hey everyone, I'm struggling getting the last bolt in of my new rear adjustable camber brackets. I can't seem to get the arm down far enough to get the top bolt in. Is there a trick to it? Do I need to deflate the hydro? (I have a pump so I don't mind letting it down). This seems like a common mod for minis and I have no idea how people get past this point! Any suggestions would be appreciated. Thanks, Nick |
Author: | Convertible Mini [ Tue Oct 30, 2012 4:08 am ] |
Post subject: | Castor brackets. |
I presume you are talking about the rears. Sometimes you might have to elongate the holes to make it easier, otherwise you will damage the thread and that will be a problem.. |
Author: | TK [ Tue Oct 30, 2012 12:43 pm ] |
Nick, I did mine a couple of weeks ago. Luckily dad helped out he was able move the arm using a lever, to get it in just the right place for me to put the bolt in. Two man job made it easier. EDIT: No I didn't let the hydro down either. |
Author: | simon k [ Tue Oct 30, 2012 2:16 pm ] |
remove the other bolts and check that the holes do actually line up properly then use a pry bar between the arm and the subframe |
Author: | TheMiniMan [ Tue Oct 30, 2012 4:24 pm ] |
yeah quite often those brackets don`t have the holes in the right places & need a bit of a mod & yes also you`ll need a bit of a lever to get it all to line up |
oops, double de-bug post |
oops trippple de-bug post |
Author: | woodwormm [ Tue Oct 30, 2012 7:42 pm ] |
I hope that's a finger/brain stutter Matt, not a palpitation! ![]() |
