It is currently Thu Aug 21, 2025 11:31 am
PostPosted: Thu Nov 01, 2012 11:56 am
Hey peeps couldnt find a howto on cleaning a petroltank so im wondering what methods you have used.
Ive just pulled the tank out of pickles and gave it a wash out with petrol , well pleanty of flaky black bits like paint " soft " not sure if its sludge or there has been a tank liner kit put through it.
So what steps did you take if any ?
PostPosted: Thu Nov 01, 2012 12:35 pm
it's wax and residue from the petrol... if there was rust in there you'd find bits of that too
I let mine dry, then held it upside down beat on the outside of it to loosen all of the stuck on crap, shook as much as I could out and then rinsed it out. Inspect for flakes of rust in the stuff you shake out
Make sure you have a big fuel filter on it when you put it back in the car
PostPosted: Thu Nov 01, 2012 12:42 pm
Awesome simon thanks for that , was getting a bit worried that i would need a new tank .
So cheers
 Post subject: Fuel Tank Cleaning
PostPosted: Thu Nov 01, 2012 12:47 pm
Location: MinisintheGong [Somewhere on the South Coast]
I was recommended to use a particular product a few years ago and sold the tank and didnt do it.
But recently, i recall reading about a product and just found it.
http://www.ppcco.com.au/products4.htm
Any comments? I need to od the same with twin tanks in an up-and-coming resto
..still waiting for the Italian Job sequel to see if the bus went down :-) :-)
I put some fine gravel in mine and shook the living crap out of it.
Then I used rust converter, rinsed and dried it.
I then had to stick a little drill into the breather pipe at top and punch a hole through the strainer on the outlet pipe, but all good. My pump has a filter on it anyway.
PostPosted: Thu Nov 01, 2012 4:10 pm
Update:
It worked , after a lot of flushing and reflushing and then banging rinsing with petrol over and over again , no black floaty bits anymore.
Also interestingly flushing the tank out with pertol into a clear container you could see the water gather into a bubble into the bottom of the container " looked quite cool with the sun shining through it ".
So thanks again simon and for the rest of the replies ," in for some spinal injections tomorrow " woohoo " so i will put the tank back in on the weekend and try fire pickles up again " oh installed one of those clear fuel filters too.
PostPosted: Thu Nov 01, 2012 5:03 pm
I started today on injecting my supercharged engine which meaqnt first stop cleaning the spi tank. I am going to use this system http://www.kbs-coatings.com.au/flow-cha ... l-on-steel
They do a 3in1 package for petrol tanks which I have.
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
PostPosted: Thu Nov 01, 2012 5:08 pm
Try caustic soda, does a great job :lol:
PostPosted: Thu Nov 01, 2012 7:22 pm
I used a handful of screws and wax and grease remover.
I needed to remove rust and scale before pouring in one of the fuel tank sealing kits.
Worked a treat, but some times took a while to get the last screw out :?
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
