It is currently Sun Aug 17, 2025 4:50 pm
 Post subject: Headlight relay
PostPosted: Sat Nov 03, 2012 1:45 pm
Does a 89/90 mini rover jap import have headlight relay on high and low beam ? Or do I have to install them if I were to update the current h4 bulbs. Thanks
PostPosted: Sat Nov 03, 2012 10:04 pm
Tomboss Breweros
Easy way to tell is to turn the lights on with the engine not running (so you can hear) and switch between low and high beam, if you hear a clicking somewhere away from the high/low switch then there is a relay.
kimini wrote:
Jimmyinamini wrote:
Users browsing this forum: Bing [Bot] and 315 guests
