It is currently Thu Aug 21, 2025 3:57 pm
PostPosted: Tue Oct 30, 2012 8:23 pm
Please give me your opinions on the following.
Before adjustment.
Rear;
Camber,
Left -0.78
Right -0.84
Toe;
Left -0.1mm
Right + 0.3mm
Front;
Castor,
Left +3.57
Right +3.63
Camber,
Left -1.63
Right -1.73
Toe;
Left -8.3mm
Right +7.7mm
After adjustment (IE $150)
Rear;
Camber,
Left -0.84
Right -0.78
Toe;
Left -0.6mm
Right + 0.7mm
Front;
Castor,
Left +0.00
Right +0.00
Camber,
Left -1.65
Right -1.61
Toe;
Left -0.8mm
Right -2.1mm
I have fully adjustable suspension and the car is used for road and perhaps in the future a bit of track fun.
What say you?
[/u]
PostPosted: Tue Oct 30, 2012 8:44 pm
Apart from the front toe setting, I preferred the look of your "before" settings.
In the after settings :
Front;
Castor,
Left +0.00
Right +0.00
*NO* castor at all? :?
Left -0.8mm
Right -2.1mm
:x blech, couldn't they at least get it even??
cheers,
Jacob
PostPosted: Tue Oct 30, 2012 8:46 pm
I think I'd ask for my money back.....
Cheers, Ian
PostPosted: Tue Oct 30, 2012 8:55 pm
With that toe out the steering wheel should be slighly off to the left.
Dalmeny
PostPosted: Wed Oct 31, 2012 8:47 am
No Castor? Thats a joke
PostPosted: Wed Oct 31, 2012 10:13 am
It would feel very vague to drive. No castor and it will wander around a lot. Something I have learnt recently, if you want the wheels to be where they should be do it yourself.
G.
1962 Mini Speed sports sedan
PostPosted: Wed Oct 31, 2012 10:17 am
What was it 'set' to?
A lot of alignment places have a computer program that lists all the factory reference numbers for the car and normally a car would be set as close as possible to that.
Those numbers are miles off factory settings.
PostPosted: Wed Oct 31, 2012 10:20 am
Take it back mate.. they didn't earn their money.
I reckon I could get it closer than that with just a tape measure and a spirit level. :P
PostPosted: Wed Oct 31, 2012 12:02 pm
Toe;
Left -0.8mm
Right -2.1mm
Take it back!
From memory castor should be 2-3 degrees to give you some steering feel and centering.
Lillee - 1969 Morris Mini K
PostPosted: Wed Oct 31, 2012 12:03 pm
Toe;
Left -0.8mm
Right -2.1mm
Take it back!
PostPosted: Wed Oct 31, 2012 2:12 pm
shouldn't the rear wheels both have toe in ?
with one toed out and one toed in wont the car be going sideways ?
PostPosted: Wed Oct 31, 2012 2:41 pm
Yes it will. It is then called a crabby Mini. :P
Mine used to crab heaps but it's perfect now (after applying some basic trigonometry, a milling machine and a MIG welder). I did Lillee's car too, after a well known suspension specialist threw his hands up in the air. No adjustable brackets needed... 8)
PostPosted: Wed Oct 31, 2012 4:12 pm
Can anyone post the ideal alignment settings please?
Front and rear?
cheers,
CJ
PostPosted: Wed Oct 31, 2012 4:50 pm
Ty, you have been ripped
take it back & ask them to get it right
front -->
toe= 1/16th" OUT--- total... that is 1/32nd" per wheel
caster= 3 to 4 deg is fine
camber= depends on what tyres you have & what type driving you intend but .5 deg to 1 deg is good
rear-->
toe= 1/16th" IN-- total,,, that is 1/32nd" per wheel
camber= .5 to 1deg is fine
if you want more race type settings (again depending on what tyre choice) then yokos like 1 to 2 deg camber
Hoosier-daddys like to be straight up & down,,, ie: no camber
that`s just all a starting point for anyone, because like i said, it depends on a pile of things, mostly tyre choice & suspension /body stiffness & what type of driving you`re intending on using the car for
sometimes a compromise may be needed
PostPosted: Wed Oct 31, 2012 6:53 pm
sweet, thanks I will file that away for later
Users browsing this forum: No registered users and 151 guests
