Tom's misc rebuild q's
https://www.ausmini.com/forums/viewtopic.php?f=2&t=79044
Author:  tomtom [ Thu Nov 01, 2012 2:43 pm ]
Post subject:  Tom's misc rebuild q's
I've been doing a search for certain queries here, but haven't gotten very far in some of these things. Mostly pretty stupid questions for sourcing parts AU vs UK.
Do the UK wipers fit a clubman?
Eg: like these: http://www.minisport.com/mini-spare-par ... S0563.html fit a 78 clubby?
My indicators aren't working, I can't hear the clicking of the flasher unit. Where is it (most likely) located?
Been trying to sort out the wiring up the back end so i can fit in the fuel tank but indicators are no go. No clicking from the flasher so i'm assuming it's a dead unit, fuse or bad indicator stalk. I have no idea where the flasher is and the two fuses I can see in the engine bay seem to be fine, I gave them a bit of a sand as well too get a better contact. Reading the haynes manual (which wiring diagram is for my car?? why is this so difficult lol) indicates that there should be more fuses which i haven't checked?
UK rubbers in Aus car?
I'm assuming the windscreen front and rear are the same.
Door to body seals?
Rear window seal?
http://www.minisport.com/mini-spare-par ... A8239.html Look rather different to
http://minisport.com.au/prod37.htm
I took out the rubbers ages ago so can't remember what they look like.
I don't have the front number plate holder. Who sells them? I can't find any! Do I just make one or does the number plate mount directly to it?
I'm sure I'll get more questions so I'll just keep them in this thread.
Thanks always guys.
Edit, another question already.
What nuts & bolts do I need to mount the bumpers ?
I'm assuming they're UNF so I'll have to order them.
Author:  keastmini [ Thu Nov 01, 2012 2:53 pm ]
Post subject:  Re: Tom's misc rebuild q's
I had this on my car recently and it was the flasher can itself, it was clicking away but not actually sending power to the lights, new flasher solved it.
Author:  tomtom [ Thu Nov 01, 2012 2:55 pm ]
Well I can't even hear the clicking...
Author:  drmini in aust [ Thu Nov 01, 2012 3:18 pm ]
Not unless you bend them at the end a bit like I did. UK LH park cars have the wiper spindles in a different spot to our Minis 1968>
Under the dash near the steering column.
Front is.
Door to body seals?
NO, buy local. UK ones are too narrow and don't seal.
Rear window seal?
Only if you get a MK1 UK one, most are wider window than ours so need cutting.
Buy local...
Try Mini King.
Thanks always guys.
1/4 UNF nuts, the studs should be in the bars already.
Author:  MiniBill [ Thu Nov 01, 2012 3:48 pm ]
Great post tomtom , im sure to need these questions answered for my project aswell ..........
Author:  tomtom [ Fri Nov 02, 2012 5:57 pm ]
Sorted out the indicators, turned out to be a faulty unit. $20 later from autobarn and we're all golden.
Question though, why are the rear indicators twin filament? Is it supposed to be reverse lights too?
Author:  Morris 1100 [ Fri Nov 02, 2012 6:01 pm ]
Yes. It has reversing lights.
Author:  tomtom [ Fri Nov 02, 2012 6:37 pm ]
But the reversing lights are orange cause it comes through the lens..?
Author:  drmini in aust [ Fri Nov 02, 2012 6:40 pm ]
Yes.
Back in 1971 they didn't have to be clear.. :wink:
This was an easy way out (long before Altezza clear lenses became the flavour of the month)
Author:  John Smidt [ Sat Nov 03, 2012 8:59 am ]
Mini King do carry an Australian made reproduction of the front number plate
bracket instock at present
