removing a body off the front Subframe and engine..
https://www.ausmini.com/forums/viewtopic.php?f=2&t=79049
Author:  Blunder [ Thu Nov 01, 2012 5:24 pm ]
Post subject:  removing a body off the front Subframe and engine..
Guys
Whats the best way to get the body up in the air to remove the Engine and subframe?
Lift points etc...
Author:  peterb [ Thu Nov 01, 2012 5:29 pm ]
I assume you mean where do you lift it? If you have engine crane, lift with sling onto holes on inner guards brace, the angle bit that goes from fire wall crossmember to inner guard.
Author:  Harley [ Thu Nov 01, 2012 5:47 pm ]
Yep, I agree with that, but you ideally want lots of height to get the sling angles closer to vertical. I use a ceiling mounted block and tackle, nice and high.
Author:  16sth [ Thu Nov 01, 2012 7:34 pm ]
Like this...
sort of.
Author:  bnicho [ Thu Nov 01, 2012 8:30 pm ]
I've always used a couple of trolley jacks to start off and then two or three string blokes to finish.
Author:  1275LS [ Thu Nov 01, 2012 10:25 pm ]
Brett do you use any special knots to make these string blokes? :lol:
Author:  MiniBill [ Thu Nov 01, 2012 11:07 pm ]
Haha a freudian slip perhaps :-) , maybe he meant three G string blokes :lol:
Author:  bnicho [ Fri Nov 02, 2012 9:24 am ]
Stupid bl**dy phone!!
