It is currently Thu Aug 14, 2025 12:47 am
 Post subject: Need a distributor cap
PostPosted: Sat Nov 03, 2012 5:21 pm
After putting the new tyres on this morning the car felt a bit funny.
Had a poke around under the bonnet and found a problem with the distributor cap.
The centre post was cracked and fell out when I took the cap off.
Raced down to Super Cheap and of course they don't have one in stock but can order it in.
They reckon it is a Bosch GL109-C.
Is this correct?
Even better does anybody on the Gold Coast have one laying around that I could buy off them?
1978 Mini S - "FAX"
PostPosted: Sat Nov 03, 2012 5:31 pm
A bosch cap on a lucas distributer? Doesn't sound right to me. You can get them from www.minisport.com.au or www.minis.com or most other aussie suppliers.
PostPosted: Sat Nov 03, 2012 5:39 pm
Lucas (original) is no more, really. All new dizzy caps now are aftermarket suppliers (even if you find one in a green `Lucas' box).
Bosch makes caps (and rotors, also points and condensers) for many non- Bosch distributors.
Including the Nissan Pulsar (Hitachi dizzy) which I have on both of mine.
PostPosted: Sun Nov 04, 2012 1:41 pm
The Mini King
Is this correct?
That number is the Bosch number for a 45D, 43D, 45DM4 or 45D4 type Dist If however You have any other model than this will not fit
PostPosted: Sun Nov 04, 2012 3:45 pm
I have plenty spare ones here you could have freebies. To suit a 45D which i think you'll have, unless its a 29D with the big clips?
I'm located at beaudesert these days though...
PostPosted: Sun Nov 04, 2012 7:26 pm
Hi Lockie91 I will send you a PM.
1978 Mini S - "FAX"
Users browsing this forum: Bing [Bot] and 224 guests
