It is currently Wed Aug 06, 2025 12:08 pm
PostPosted: Tue Nov 06, 2012 6:15 pm
Is there a way to fix leaking petrol caps the non locking chrome type.
PostPosted: Tue Nov 06, 2012 6:17 pm
Does the seal have much pressure on the filler neck when you screw it on?
PostPosted: Tue Nov 06, 2012 6:22 pm
The problem is usually the tank and not the cap.
Drmini cut the neck off his tank and fitted a repair kit
PostPosted: Tue Nov 06, 2012 6:26 pm
Yeah I rinsed the tank a few times with hot water, then filled it with cold water to the bottom of the neck while I oxy welded it.
The weld is inside the rubber grommet so can't be seen.
PostPosted: Tue Nov 06, 2012 6:34 pm
Often the cork seal is crushed and doesnt allow it to seal. Get the centre from the chest cover cork gasket from a small bore gasket kit and cut a new one seal for your cap. initally it will be tight but it wears in.
The cooper s chest-cover cork is too thick.
Brenton
PostPosted: Tue Nov 06, 2012 6:45 pm
Many tanks have damaged bayonet lugs in the top (or the sealing face bent) from bogans levering locking caps off to pinch fuel.
Neoprene rubber is a better seal than cork, which tears up from the cap being turned.
You can buy the right size neoprene seals at a boat shop (they are used on S/S cruisetanks, which take the same cap size as a Mini). :wink:
[edit] I'm talking Mini sedan tanks here, your woody's neck may be different diameter (I've never measured one).
PostPosted: Tue Nov 06, 2012 7:10 pm
The Mini King
mini king have genuine replacement seals in stock
PostPosted: Tue Nov 06, 2012 7:33 pm
Thanks for the tips , Doc I sold the woody about 3 yrs ago now I have just finished a replica S , see the event photos for the mitg run last weekend, the caps are old so your solution or Johns are the go ,thanks.
Users browsing this forum: Bing [Bot] and 93 guests
