Door Card Covering
https://www.ausmini.com/forums/viewtopic.php?f=2&t=79089
Page 1 of 2
Author:  Dabid [ Mon Nov 05, 2012 1:38 pm ]
Post subject:  Door Card Covering
Hi, I want to make some new door cards and cover them, with either Vinyl or something similar to speaker box carpet, what have people found to work best for them?
Author:  doogie [ Mon Nov 05, 2012 4:01 pm ]
Vynil, with a thin foam backing underneath.
Doogie
Author:  doogie [ Mon Nov 05, 2012 4:02 pm ]
Doogie
Author:  Harley [ Mon Nov 05, 2012 4:06 pm ]
I'll add onto that: it may be an idea to try and use mdf or ply thats has a coating of something to stop it absorbing any moisture in the door and going soggy, if you can't buy it that way there will be something in a spray can.
Author:  steve1965 [ Mon Nov 05, 2012 4:48 pm ]
I used mdf to make all new panels front & back, i also covered them in velour material they have been on the car for six years now & still look brand new.
Author:  MiniBill [ Mon Nov 05, 2012 5:30 pm ]
Damn nice mini Steve....... i will be doing my doorcards myself aswell , using vinyl and going to check out clarke rubber/spotlight for some thin foam padding and some glue , making a template with the current doorcards and using Mdf/That old stuff used on back of wardrobes " cant remeber the name :-) " .
Bought a little jigsaw to hopefully cut out the handle holes etc , good fun little project me thinks.
Author:  Dabid [ Mon Nov 05, 2012 5:35 pm ]
thanks gents,
was going to use masonite, I think that has a coating on one side and quite rough the other so the glue for the vinyl sticks to it.
Author:  d1ck0 [ Mon Nov 05, 2012 6:07 pm ]
Corflute works well too - the stuff a lot of real estates use for heir small signs these days.
Dicko.
Author:  womble99 [ Mon Nov 05, 2012 6:12 pm ]
Dicko.
Damn Dicko, that sounds like a good idea
Author:  MiniBill [ Mon Nov 05, 2012 6:32 pm ]
Dicko.
Damn i must be getting old " i am :-) " but what sort of material is Corflute , is it expensive .................. and finally where can you buy it as i would like ro have a looksee
Author:  d1ck0 [ Mon Nov 05, 2012 6:35 pm ]
It's a corugated PVC
Most sign places should sell it. I get it in Maitland from EB signs.
Dicko.
Author:  Morris 1100 [ Mon Nov 05, 2012 7:28 pm ]
MiniBill wrote:
Dicko.
Just wait till election time and all the major political parties will give you as much as you want.
Author:  womble99 [ Mon Nov 05, 2012 7:31 pm ]
MiniBill wrote:
Dicko.
true dat
Though it will have some ugly dudes mug on it :shock: :shock:
Author:  goodie [ Mon Nov 05, 2012 7:56 pm ]
Places that make computërised signs should be able to get "coreflute " for you .
Author:  Harley [ Mon Nov 05, 2012 8:33 pm ]
What do estate agents do with the signs once a property is sold?
